gearhead123
Jan 12, 2012Novice
Please help me with my access point setup :(
Hi I have a BT Business broadband router 2wire i think its called. I also have a netgear WG102 access point, i want to connect the two so i can pick up wireless internet from the access point. This...
bob5244
Jan 12, 2012Aspirant
I think what you're trying to do is wireless bridging but I don't know if the BT Business hub can do it as I don't have one. If it can there will be some settings you need to change to tell it to repeat its signal to the access point of your choice, called in netgear's access point settings "wireless point to point bridge".
If you google 2wire wireless bridging you get some results which are about turning the 2wire into "just a modem" which is not what you want to do.
Sorry I can't be of much more help
