gearhead123
Jan 12, 2012Novice
Please help me with my access point setup :(
Hi I have a BT Business broadband router 2wire i think its called. I also have a netgear WG102 access point, i want to connect the two so i can pick up wireless internet from the access point. This...
gearhead123
Jan 12, 2012Novice
bob5244 wrote: I think what you're trying to do is wireless bridging but I don't know if the BT Business hub can do it as I don't have one. If it can there will be some settings you need to change to tell it to repeat its signal to the access point of your choice, called in netgear's access point settings "wireless point to point bridge".
If you google 2wire wireless bridging you get some results which are about turning the 2wire into "just a modem" which is not what you want to do.
Sorry I can't be of much more help
Yes i did at first think it was wireless bridging that i needed to do, but repeater mode makes much more sense.
I am thinking i may have to give the AP the wireless security key off the BT router, but the security type on the BT router is WPA2-PSK and the security type on the AP only has options for WEP and OPEN. I did think about changing the security type on the BT router to WEP but i didnt want to mess with that and end up screwing somthing up and end up with no internet!
This is a nightmare, i will probably ring netgear tomorow and see if they can help and BT too.
