gearhead123
Jan 12, 2012Novice
Please help me with my access point setup :(
Hi I have a BT Business broadband router 2wire i think its called. I also have a netgear WG102 access point, i want to connect the two so i can pick up wireless internet from the access point. This...
gearhead123
Jan 13, 2012Novice
bob5244 wrote: Ok I understand now what you're trying to do. Yes if you want the AP to be a repeater you will need the wireless security types to be the same with the same SSID and password
I already tried changing the SSID on the AP to the same as the 2wire, all this seemed to do was change the name in my available wireless networks list so i had two BT Business Hubs listed, instead of one BT hub and one NetGear AP??
