gearhead123
Jan 12, 2012Novice
Please help me with my access point setup :(
Hi I have a BT Business broadband router 2wire i think its called. I also have a netgear WG102 access point, i want to connect the two so i can pick up wireless internet from the access point. This...
bob5244
Jan 13, 2012Aspirant
jmizoguchi wrote: you don't need to do this if your installing WG to 2wire with ethernet cable.
I believe that the access point is standalone and not connected with an ethernet cable, hence needing repeater mode
