rgriffith98
Feb 19, 2014Aspirant
Please Help
I have a Netgear WNR1000v2 wireless router and I want to be able to set up a time frame that will shut off the wireless from being used on all devices mainly the xbox. I have tried setting up under t...
Retired_Member
Feb 19, 2014I don't have this router and the online manual is somewhat useless. Look for advanced settings, wireless. If it has the option to turn off using schedule it should be there.
If you get this far, hit apply when setting schedule and hit apply a second time after ticking turn off by schedule
