arvesper
May 27, 2019Aspirant
Please recommend WiFi Range Extenders compatible with WNDR4500v3
May 28, 2019Guru - Experienced User
the WNDR4500v3 is a N900 router. Do you plan on upgrading in the future to a better router?
How large of an area are you trying to cover?
What is the usage case for this? reason I ask is there are standard extenders, dual band extenders, and tri-band extenders that use a wireless backhaul for connecting back to the router.
Alot depends on your usage goals, house size, and budget.
