GJSchaller
Jun 10, 2019Guide
PLW1000 and Netgear Router running Tomato firmware
I currently have a Netgear R7000 router at home running Tomato firmware (latest release, which I believe is 2019.2). There is one room in my house that has poor WiFi, and I'd like to boost the signa...
Jun 11, 2019Guru - Experienced User
in terms of the pl1200, its tech specs show its
- HomePlug® AV2 compliant
- Works with HomePlug AV and HomePlug Green PHY
The plw1000 is:
So they should work together. The HomePlug AV2 spec requires devices to work together to be certified. So they should. Emphasis on should. :)
In terms of powerline working with tomato. it will. Powerline doesn't care what its connect to. If your powerline 1200 adapters work with it, so will the plw1000's.
