JM140's avatar
JM140
Follower
Apr 10, 2020
PLW1000 can't login after reset
Hi,
I'm installing these powerline adapters and am trying to make a roaming network outof them (same network ID and password so it's seamless and devices decide which one to use) However, after I did a factory reset, I can no longer access the router settings. I have used the username admin and password password and have never changed these.
I have tried:
-multiple resets on the WIFI unit, and the powerline unit
-logging in with different browsers
-logging in with different machines
-logging in using routerlogin.net
-unplugging both units for an hour
-calling tech support (was 'accidentally disconnected once, and told they'd call me back the second time. I know they are super busy)
-using the NETGEAR Genie application
nothing works.
I believe the unit thinks someone is already logged in and the reset isn't fixing it.
weird...Any advice?
No RepliesBe the first to reply
