Pete422
Aug 20, 2020Aspirant
PLW1000 Setup question
Hi, I've just set up a PL1000 & PLW1000; I can connect my laptop wirelessly to the WiFi adapter , but it says "Connected, No internet". The lights on the 'base' Adapter are :Power, green....Ethernet,...
Pete422
correction, the Pick a Plug lite on the base Adapter is Red
- plemansAug 21, 2020Guru - Experienced User
Try moving the adapters to the same room and trying them. If the pick-a-plug light is off or red, it means poor connection/no connection.
And many things impact powerline connections. these include:
cheap made electronics
gfci outlets
arc fault breakers
surge protectors
high draw appliances
bad/cheap cell phone chargers
distance
old/poor wiring
