JamesJM
Apr 17, 2019Aspirant
PLW1000 stopped working when I tried to using it in a different electricity socket
PLW1000 stopped working when I tried to using it in a different electricity socket. Using with Virgin Media broadband.
- Apr 17, 2019Adding an extension shouldn't wreck it. It just won't work as well. Did something arc? Arcing something could wreck it.
You could try a reset by holding the reset button in for 10 seconds while its plugged in.
Apr 17, 2019Guru - Experienced User
so you're saying it works but when you moved it to a different outlet, it doesn't?
Powerline is sensative to arc fault curcuits, gfci curcuits, and different types of interference. here's an article that goes over some of the devices that cause problems with powerline and what you can do to minimize those.
https://www.makeuseof.com/tag/6-tips-improve-speed-powerline-network/
JamesJM
No it stopped working completely. It won't power up anymore. I had mistakenly connected an extension/strip. Now it does not power up in any type of socket.
