lewgb
Nov 26, 2021Follower
plw1000v2 adaptor
Hi guys, I recently set up my netgear wireless extender and want to add extra adaptors, where can I purchase just the adaptor without having to buy the bundles.
Nov 27, 2021Guru - Experienced User
Netgear only sells the bundles.
but you do have options.
1. you can buy them 3rd party from places like ebay.
2. you can buy other brands. Powerline devices use a spec and if you get the same spec, you can switch between manufacturers.
Adding a powerline adapter to an existing powerline network | Answer | NETGEAR Support
