woodhill
Dec 01, 2022Tutor
Poor Wi-Fi speed with EX7700 connected to an Asus RT86U
 Hi, my EX7700 has started to perform poorly. I have it connected to an Asus RT86u router and have a 150mbs fibre connection. But I can only manage around 60mbs across the wi-fi network. I have tried ...
- Dec 02, 2022Plemans, many many thanks. You have been so helpful. Before I saw your email(s) I decided to move the extender a little closer to the router. I moved it to the other side of a stud and plasterboard wall, a distance of no more than 1 metre, and what a transformation. Now in the main (living) room away from the extender, I get speeds approaching 140mbs on the 5ghz channel! I cannot believe a distance of only approx. 1metre and avoidance of a thin wood and board partition could make so much difference. For now, I will resist any further changes but if it deteriorates, I will look again at your suggestions. Thanks for explaining fronthaul and backhaul. It was clearly a backhaul problem!
woodhill
Dec 01, 2022Tutor
Thanks Plemans, but what is fronthaul and backhaul? Excuse my ignorance! And how to check?
The speeds I am getting are whilst connected to 5g (SSID: AUS RT-AC86U_5G).
I've tried changing 2.4ghz and 5ghz channels. Can you suggest what to? On the ASUS router the control channel only goes up to 112. I've currently got it set to 48.
What do you mean by "hardwired" connection? Is this the ethernet connection as used with the installation assistant?
Thanks in advance...
Dec 01, 2022Guru - Experienced User
The tribands have a dedicated backhaul.
Thats the 5ghz connection between router and extender.
the fronthaul is the connection between the extender and devices.
So we want to be sure the backhaul (router---extender) connection is operating at speed.
so if you directly wire a pc/laptop into the extender and test its speeds, it'll tell us how that backhaul is operating (as a hardwired connection will only rely on the backhaul).
