OutsidetheBox
Dec 02, 2012Follower
Port Forwarding / Static Address / Mac User
Just went to FAQ and searched for those terms and got "no matches," so I am wondering if I'm in the right place. Those terms (Port Forwarding and Static Address) are in the router manual, so it's hard...
jmizoguchi
Dec 02, 2012Virtuoso
My underlying problem is that, after many months of flawless, convenient operation, my uTorrent software now loads the 'magnets' (whatever they are - I don't understand the terminology or more than the most general outline of how P2P works) and they sit on 0%!
If you had same router and has worked on torrents then suspected to be either possible ISP blocking the torrents or something else.
Most app will able to use uPnP setting which are usually enabled at default on most router so should work
