Michaelwh
Nov 12, 2013Aspirant
Ports forwarding without setup
I heard that UPnP could be a security issue, so yesterday I disabled it. I have port forwarding turned on for 2 applications, however I'm able to use other ports that are not currently explicitly set...
fordem
Nov 12, 2013Mentor
I'd suggest you start by resetting the unit to factory defaults & then reconfiguring - there have been cases reported of forwarded ports not being displayed, and a reset would/should clear any such settings out.
