EASIE
May 21, 2020Aspirant
Power light LED stays amber all the time
EASIE
Worked well for months but cannot reset with amber power light on always
May 22, 2020Guru - Experienced User
sounds like something got corrupted. you can try recoving via tftp.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
- HackedOffUserMay 26, 2020Initiate
I'm sure I have the wrong end of the stick but the original question is specifically about the EX6110 which doesn't have an ethernet socket so with the best will in the world I'm never going to be able to connect it to a wired computer. I also note that the EX6110 is not listed in the applicable models in the right hand column
I have had the extender less than 3 weeks and, up until last night, it has been perfect; now I appear to have a very expensive nightlight and instead of working from home I spent most of today definitely not working from home but trying to reconnect to the internet.- plemansMay 27, 2020Guru - Experienced User
My bad. without the ethernet jack, there's not way to recover it if it is corrupted.
You can check to see if the warranty is still valid. click on mynetgear at the top. register an account and then the device. From there you can check warranty status.
- HackedOffUserMay 27, 2020Initiate
Hi Plemans, thank you, please accept my apologies for sounding so pissy last night, I'd had a long, hot, frustrating day trying to get stuff done with no connection and most definitely wasn't feeling the love.
I had a couple of cold beers and a decent sleep and bought another extender this morning, so the sun is shining, the birds are singing and all is right-ish with the worldAppreciate you efforts to help
Steve
