Shannon1653
Oct 10, 2018Aspirant
Power line adapter for detached garage
We have a detached shop and purchased a wireless camera system. Only the camera by the window gets a signal to the NVR in the House. We purchased a new NETGEAR Nighthawk to try and boost the signal. Still only the one camera works. Would a power line adapter actually boost the signal in the garage? The cameras are all wireless and I think the metal siding and door are causing the interference. I can run a cat6 to the garage but I don’t think this will help since the cameras are trying to connect to the NVR in the house. I would move the NVR to the shop but then I don’t think the outdoor cameras will connect. Any suggestions? Thank you.
A powerline adapter extends ethernet over your house wiring. It's basically equivalent to running a cat6 cable to the garage, though the speed wouldn't be as fast.
Some powerline adapter kits include a wifi module - that would create a new wifi signal in the shop that the cameras could potentially connect to. Similarly, you could connect up an extender or router to the cat6 cable and create a wifi signal that way.
Can you tell us the manufacturer/model number of the NVR? It'd be helpful to sort out whether cameras are connecting to your main wifi network, or if the NVR is includes it's own wifi network.
Also, what is the distance from the house to the shop? Does the shop have it's own power main, or does the power come from the house?
- Shannon1653Aspirant
The NVR is a Wisenet SNR-73201W. The shop is approximately 35 ft from where the NVR is in our home. The power runs from the house to the breaker box in the shop. I have tried just a Wi-Fi extender and have the same problem that it won’t connect with the router in the house. We tried to run an Ethernet to the extender to see if that would work but the extender only has an out port so no luck. I’m not really that knowledgeable with this stuff and live in a small town where we have a computer store but they are not very knowledgeable with security systems.
Hi Shannon,
I guess it isn't possible to move the NVR to a window adjacent to the garage?
When you look for an access point on your mobile phone, do you see the NVR network in the list? How do you pair a camera with it - do you need to specify a network name and password? If you see the NVR network and have control over the name/password used then you may be able to use an extender to assist here, otherwise the camera will be connecting using a proprietary method which you unlikely to duplicate using an extender.
Last resort for me would be to unscrew one of the aeriels on the back of the NVR (if they can be unscrewed easily) and take it down to an electronics shop - ask whether they have a high/very high gain aeriel with the same screw connector - or alternatively ask if they have an extension lead that you could run from the aeriel connector on your NVR into your garage, and connect the aeriel to it there. This link shows the type of thing I'm talking about, however it would need to have the correct connectors to match your NVR aeriel socket. https://www.reichelt.com/gb/en/wifi-aerial-cable-n-plug-n-coupler-10-m-lan-wl-ak-nsnk10-p47244.html
Cheers
Nick
