GordoNZ76
Mar 22, 2020Aspirant
Powerline 1000 no Internet connection
Hi Guys. I have all the lights on both the adapter connected to the modem via ethernet cable and plugged directly into a power socket, plus the adapter that is used to send the wifi signal to the ar...
GordoNZ76
Thanks for the reply. All the LEDs are showing as solid green (or blue), not blinking. Which do I want, solid or blinking?
No appliances have been added, and yes, I've been trying to connect in the same room.
Mar 22, 2020Guru - Experienced User
solid color is what you want.
did you find out if you have the plw1000?
here's the support site for that device
https://www.netgear.com/support/product/PLw1000
