Dbyers
Dec 17, 2019Follower
Powerline 1000 wifi won’t turn on again
Just bought this unit a couple hours ago. Plugged it into the router and all lights came on immediately. Plugged the adaptor into an outlet in my garage and all lights came on immediately to it as wel...
Dec 18, 2019Guru - Experienced User
I know this sounds stupid but it does have a power switch on the side of it. Did you try turning on/off? whenever the lights don't turn on at all, its usually a function of the power switch. Or something was broken while unplugging.
Or did pushing and holding the reset button while powered on?
