JohnJenkin
May 29, 2019Follower
Powerline 1000
I have installed the Powerline as per instructions and have green lights on all units. When I try to log in, I'm asked for the Network Code, but when entered it is not accepted. It is the correct code and works when used within the current router range. What to do?
1 Reply
JohnJenkin wrote:I have installed the Powerline as per instructions and have green lights on all units. When I try to log in, I'm asked for the Network Code, but when entered it is not accepted. It is the correct code and works when used within the current router range. What to do?
I'm not sure what you're stating that its the correct code and works when used within range of the current router. What are you meaning by this? More details help. How are you accessing the powerline? When isn't it working exactly.
