DrKim's avatar
DrKim
Guide
Sep 10, 2019
Powerline 2000 connectivity issues with Haywood pool controller
My pool builder was having trouble getting an external atennae to connect with our wifi.  Connection wouldn't hold.   He asked our pool equipment supplier for help and they suggested these Netgear ...
  • DrKim's avatar
    DrKim
    Sep 29, 2019
    After several conversations with you and conversations with my pool builder, we have ginally fixed this problem.  My pool builder was not aware that I would have problems with the Powerlines if they were not on the same circuit.  What we finally did was move the Powerline device to my utility room which is the closet room to the pool controller and we plugged the Powerline into that circuit, same circuit as the ohter one.  Then we drillled a hole through the wall and ran a cable from that Powerline directly into my pool controller.  Now my problem is finally fixed.
    Thank you for your consult and good advice.
