DrKim
Sep 10, 2019Guide
Powerline 2000 connectivity issues with Haywood pool controller
My pool builder was having trouble getting an external atennae to connect with our wifi. Connection wouldn't hold. He asked our pool equipment supplier for help and they suggested these Netgear ...
- Sep 28, 2019
After several conversations with you and conversations with my pool builder, we have ginally fixed this problem. My pool builder was not aware that I would have problems with the Powerlines if they were not on the same circuit. What we finally did was move the Powerline device to my utility room which is the closet room to the pool controller and we plugged the Powerline into that circuit, same circuit as the ohter one. Then we drillled a hole through the wall and ran a cable from that Powerline directly into my pool controller. Now my problem is finally fixed.
Thank you for your consult and good advice.
Sep 13, 2019Guru - Experienced User
Its very possible that the extender in the house with hooking the wireless antenna back to the controller might works. Or the extender connected via ethernet jack might works. Its one of those things you're going to have to play with to see what works.
DrKim
Sep 28, 2019Guide
