panguerreiro
May 05, 2020Aspirant
Powerline 500 XWN5001 reset
Hi I recently reinstalled my Powerline 500 XWN5001, I've made a reset and all the connections work good. My issue is that now I've a wifi line without password protection since the Netgear Powerlien...
May 05, 2020Guru - Experienced User
Are you able to connect to the wifi?
How about using the IP address of the AP (access point) to log into it and manage it?
The manual also shows using the genie to manage it. Have you tried this?
https://www.netgear.com/home/discover/apps/genie.aspx
here's where you can get the install guide and manual to manage it.
https://www.netgear.com/support/product/XWN5001.aspx
- panguerreiroMay 12, 2020Aspirant
Hi plemans
it connects to the wifi.
How can I use IP address of the AP (access point) to log into it and manage it?
Genie is not detecting any appliance when I open it on my mac and the new version, only shows controls for routers and I only have the poweline repeaters from Netgear- plemansMay 12, 2020Guru - Experienced User
I don't have that specific model but if you have the IP address of the device, you can type that into your browser to access the setup/settings that route instead of the genie.
or when you're connected try mywifiext . net (remove spaces, it doesn'tt let me post them without the spaces)
default login is admin
default password is password
