panguerreiro
May 05, 2020Aspirant
Powerline 500 XWN5001 reset
Hi I recently reinstalled my Powerline 500 XWN5001, I've made a reset and all the connections work good. My issue is that now I've a wifi line without password protection since the Netgear Powerlien...
panguerreiro
May 12, 2020Aspirant
Hi plemans
it connects to the wifi.
How can I use IP address of the AP (access point) to log into it and manage it?
Genie is not detecting any appliance when I open it on my mac and the new version, only shows controls for routers and I only have the poweline repeaters from Netgear
May 12, 2020Guru - Experienced User
I don't have that specific model but if you have the IP address of the device, you can type that into your browser to access the setup/settings that route instead of the genie.
or when you're connected try mywifiext . net (remove spaces, it doesn'tt let me post them without the spaces)
default login is admin
default password is password
