dougjp
Apr 12, 2021Tutor
Powerline Adapter PLP2000 - Can a Wifi Range Extender Be Added?
I may be lacking in tech knowledge, but even I find my subject description to be strange! I'd better detail my problem :smileyembarrassed: Maybe there is a simple solution. My ISP recently force...
- Apr 12, 2021
Most (not all) of netgear range extenders support access point mode.
So you can hardwire in most of them. Same with the routers. As far as I know, all of them support access point mode.
So most of the range extenders and routers will support access point mode and be able to be hardwired in
Apr 12, 2021Guru - Experienced User
Yes.
You can connect a wifi extender to that and run it in access point mode.
You could even connect a router and run it in access point mode (if you had an old router)
There's all kinds of extenders/routers that could be used.Its tough to recommend without knowing more about your setup/home/usage/budget.
