Chuckbo's avatar
Chuckbo
Powerline extender not accessing the internet
I have been using my PowerLINE WiFi 1000 and PW1000 extender for several years very successfully -- it provided internet access to a guest house that we had.
But I'm having trouble using it in the garage of our new house and can't figure out why, even though I'm getting a stronger signal. I have the PowerLine 1000 connected via ethernet to an Asus CM32/AC2600 router/modem. I have the PLW1000 slave unit in the garage. I have a blue signal for WiFi. I have a green signal for Pick-a-plug. And I have a green light on the Power. I'm able to see the network on the iPad and join the network using the default password, but the iPad gives me a message that I'm not connected to the internet. What am I forgetting to do?
  • Oh yeah, I've tried that, too.
    But I think I have a laptop to test the ethernet from the router tomorrow.
  • I guess i'll start with the basics here.  No airplane mode turned on the iPad correct?
    • Chuckbo's avatar
      Chuckbo
      Unfortunately, Airplane Mode is not turned on.
      When I was able to bring the iPad into range of the main signal, I was able to access pages without any problem.
      I'm wondering if it's possible that something's interfering with the internet from the router, over the ethernet, to the master powerline. I have to borrow a laptop with an ethernet port to check that out.
      • Coaleyed's avatar
        Coaleyed
        Guide
        Tried reloading the router then reloading the extender to see if a fresh set of links resolves the issue?
