liv2hunt
Feb 04, 2020Tutor
Powerline networking
I currently have the PLW1010 set up between my home and my garage which has metal walls. My home WiFi is not able to reach inside the garage due to the metal walls. My signal inside the garage is ade...
DexterJB
Feb 05, 2020NETGEAR Moderator
Hi liv2hunt, welcome to the community! Yes, that will work. However, it is recommended that the devices (extenders) are placed at an optimum distance between each other and work on the best wireless channel available to lessen wireless interference.
Dexter
liv2hunt
Feb 05, 2020Tutor
Dexter,
Thanks for the info. As I am sure you are aware, the PLW1010 works on two channels, 2.4 and 5GHZ. If I am correct, the 5ghz is less likely to penetrate walls etc and it is what I use inside the garage since I also belive it is a faster channel. That said, I will search for an outdoor model that is only 2.4GHZ (since I believe it is the channel with longest range also) and use that outside the building.
Does that sound like a good plan?
