liv2hunt
Feb 04, 2020Tutor
Powerline networking
I currently have the PLW1010 set up between my home and my garage which has metal walls. My home WiFi is not able to reach inside the garage due to the metal walls. My signal inside the garage is ade...
DexterJB
Feb 05, 2020NETGEAR Moderator
Hi liv2hunt, welcome to the community! Yes, that will work. However, it is recommended that the devices (extenders) are placed at an optimum distance between each other and work on the best wireless channel available to lessen wireless interference.
Dexter
liv2hunt
Feb 05, 2020Tutor
On another note, does the ethernet plug on the PLW1010 support POE? Most of the outdoor units that I am seeing are powered in that manner which makes perfect sense.
I do not see anything about POE in the manual for the PW1010.
