JayRutherf
Apr 16, 2020Aspirant
Powerline PL1000 1GBps not reaching anywhere farther than a single room away
I had just gotten a Netgear Powerline PL1000 today to create a stable connection from one side of the house to the other. The distance is not far at all (good enough for a full wifi connection). I te...
- Apr 16, 2020
You might end up having to return it. not all homes work well with powerline due to how many things can add interference. this could be arc fault circuits, gfci circuits, surge protectors, high draw appliances, bad/poorly wired electronics, even the wiring iteself can cause issues. or poor/cheap cell phone charges. The test to see if the powerline device is working properly is to set it up on the same circuit. which you did and it worked fine. So you're home might not be ideal for powerline or you might need to do some investigating of the home/appliances/devices plugged in.
Apr 16, 2020Guru - Experienced User
JayRutherf
Ok, thank you for the clear response!
