David1946
Aug 17, 2017Aspirant
PR2000 Firmware Updates
PR2000 Range Extender
Firmware Update V1.0.0.17_1.0.1
I am unable to implement the update according to your instructions as I cannot access the maintenance page on the TREK.
I have connected the TREK LAN socket to my PC using an Ethernet cable, switched the TREK to wired
I then open a browser and search for http://192.168.168.1 and the TREK then returns the error message:-
No Ethernet cable is plugged into the router internet port.
If I connect the Ethernet cable to the Internet/Lan socket I get the same error message.
I have previously set the TREK to work in range extender mode which it does and still is working OK.
Can you explain what I am doing wrong or what is not working.
- DarrenMSr. NETGEAR Moderator
Hello David1946
Try page 19 on the manual
http://www.downloads.netgear.com/files/GDC/PR2000/PR2000_UM_Cellular%20Version_09Apr2014.pdf
DarrenM
- David1946Aspirant
I did not get the answer I needed.
I have tried the procedure detailed on page 19 but I did not have a connection from the TREK to the modem/router, i.e. I omitted Step 1 for 2 reasons:-
1) I did not see why a connection to the TREK would be required if I was only updating the TREK firmware and not accessing the internet.
2) I am using the TREK as a range extender and the router is too remote for access.
Can you please explain why a connection to the internet is necessary when only updating the firmware.
Regards
