WoodGuy
Jun 23, 2017Follower
PR2000 V15 download Disk Image File is corrupt
I have downloaded the PR2000-V1.0.0.15_1.0.1 upgrade repeatedly, but continually receive a "The disc image file is corrupted" message when I try to open.
DarrenM
Jun 26, 2017Sr. NETGEAR Moderator
Hello woodguy
Are you trying to open the file on your PC? You should just log into the router go to the firmware page and browse files and select the firmware file then try to load it.
DarrenM
