K4955
Oct 14, 2021Aspirant
Print share using Wi-Fi Range Extender
I own EX6200/AC 1200 which has USB Port. When I connect a flash drive to the USB Port, READYSHARE picked up and enables sharing of the flash drive. From my windows 10 64 bit computer if I select Star...
olympos1625
Oct 16, 2021NETGEAR Employee Retired
Hi K4955,
Welcome to NETGEAR Community!
Thank you for reaching out. Did you follow the steps on the Readyshare print manual on page 11?
https://www.downloads.netgear.com/files/GDC/ReadySHARE_Apps/ReadySHARE_Printer_UM_19Aug2015.pdf
If yes, are you getting error message when selecting the " Network Scanner?"
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
K4955
Oct 17, 2021Aspirant
The URL pointed in the manual that was suggested by you shows error to open the web page. Can you please give me the direct URL for downloading Readyshare Printer share utility for Windows 10 64bit?
The multi functional printer is connected to NETGEAR AC1200 using Ethernet cable, printer is shared in Windows PC and configured as Network printer to use a dedicated static IP address. The USB cable is connected between the printer and Windows PC directly. The static IP address responds in all 4 counts when pinged.
My intention and wish is to use the scan feature of the printer using NETGEAR Readyshare Printer Utility.
Thanks
- olympos1625Oct 26, 2021NETGEAR Employee Retired
Hi K4955,
We would like to do a follow-up on this one. Do you still have the issue?
Oliver
Community Team
