K4955
Oct 14, 2021Aspirant
Print share using Wi-Fi Range Extender
I own EX6200/AC 1200 which has USB Port. When I connect a flash drive to the USB Port, READYSHARE picked up and enables sharing of the flash drive. From my windows 10 64 bit computer if I select Star...
olympos1625
Oct 16, 2021NETGEAR Employee Retired
Hi K4955,
Welcome to NETGEAR Community!
Thank you for reaching out. Did you follow the steps on the Readyshare print manual on page 11?
https://www.downloads.netgear.com/files/GDC/ReadySHARE_Apps/ReadySHARE_Printer_UM_19Aug2015.pdf
If yes, are you getting error message when selecting the " Network Scanner?"
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
olympos1625
Oct 21, 2021NETGEAR Employee Retired
Hi K4955,
Thank you for the update. Please try to remove the USB cable to your computer and printer since the printer is already connected via Ethernet cable to the router. Then try to test if the Network Scanner is working. If there is any error message, please send it to us.
Oliver
Community Team
