bao450
Aug 18, 2011Aspirant
Probl. Setting up 2x WG302v2
Hi
Having a hard time configuring two identical WG302V2 as repeater with client association. I have followed the instructions on the web site and nothing is working.
AP1 is connected to the ethernet network, AP2 is not (too far).
everything is configured the same : IP subnets, SSID, channel, etc. I also entered mac addresses in the remote field for both (as stated in the procedure)
My wireless laptop can connect to the SSID.. I get an IP address from a AP.. but I'm unable to ping either both AP or even the default gateway (all configured in the same subnet 192.168.0.0/24).
Did I miss something that was not in the manual ?
Thanks
Thanks
- bao450AspirantBTW, I'm using the latest firmware on both Access Point = 5.2.9
- jmizoguchiVirtuosohttp://interface.netgear-forum.com/WG302/dhcps.htm
you are not using this correct? make sure you don't. - bao450AspirantBoy, your screenshot is old.. you are using firmware 4.x something.. do you have something newer ? The screen doesn't have the same options with the latest firmware
