conan1k's avatar
conan1k
Tutor
May 07, 2020
Problem with Extender EX7700 setup
I just noticed this during the setup of my new EX7700 extender to my Netgear Router R7960P.   I used the smart setup, which worked fine, and it shows the connection up and running. BUT....I noticed...
  • plemans's avatar
    May 07, 2020
    You don't.
    its designed for 1 of the 5ghz bands to be in the lower 5ghz band and the other 5ghz to be the upper.
    Or they'd interfere with each other and cause issues.
    If they were able to be on the same channels, they wouldn't be able to broadcast at the same time and it'd be pointless to have a tri-band router.
