Ogiee
Jul 14, 2022Tutor
Problem with wifi extender EX6120
I Have a problem . Firstly my extender lost connection to router but i coudl still log into extender wifi without the internet . After looking on help sites I done a factory reset but now wanting to c...
- Jul 14, 2022Dude after all this crap i found solution that i made my self xD In the router setings i black listed 1 thing that that extender was working on because i brought it back and extender now works as intendet . I was woried that that was sth other and was stealing my internet soooo sr for making You on feet to help me. If someone has similar problem i recommend checking your conncted devices . I dont know but i was working with it on the black list for like 4 weeks it just suddenly stoped . Thats why i coudn't connect it by WPS or so . Much thanks dude still for your time have a lovely day and i give you much credit for your suggestions 🙂
Jul 14, 2022Guru - Experienced User
Don't connect it to the router with ethernet. Reason why is when its hardwired into the router, it needs to be setup in access point mode and not extender mode. You'd have to re-run setup.
After your reset, did you try setting it up using the installation assistant? If not, try that. Here's a video of how to.
https://www.youtube.com/watch?v=yJVklshxBMk
you might need to factory reset 1 more time to get back to default if you were clicking on the wps button.
