Ogiee
Jul 14, 2022Tutor
Problem with wifi extender EX6120
I Have a problem . Firstly my extender lost connection to router but i coudl still log into extender wifi without the internet . After looking on help sites I done a factory reset but now wanting to c...
- Jul 14, 2022Dude after all this crap i found solution that i made my self xD In the router setings i black listed 1 thing that that extender was working on because i brought it back and extender now works as intendet . I was woried that that was sth other and was stealing my internet soooo sr for making You on feet to help me. If someone has similar problem i recommend checking your conncted devices . I dont know but i was working with it on the black list for like 4 weeks it just suddenly stoped . Thats why i coudn't connect it by WPS or so . Much thanks dude still for your time have a lovely day and i give you much credit for your suggestions 🙂
Jul 14, 2022Guru - Experienced User
What firmware is on the extender?
What router are you connecting it to?
What modem/gateway is the router connected to?
If you log into your router, are you able to view the extender under the attached devices list?
Ogiee
Jul 14, 2022Tutor
- plemansJul 14, 2022Guru - Experienced User
Glad you got it fixed!
You might mark it solved so others aren't still trying to fix it.
Plus it helps others find the solution.
