Genny28
Aug 16, 2021Aspirant
Problemi con extender
Salve sto riscontrando problemi di segnale del extender con il router. Ci tengo a precisare che dall'acquisto del prodotto fino a due giorni fa tutto funzionava senza alcun intoppo. Come posso risol...
Aug 16, 2021Guru - Experienced User
What problems are you having?
What firmware is on the extender?
What router is it connected to?
What method of setup did you use? WPS or the installation assistant
- Genny28Aug 17, 2021AspirantThe model is a AC750 WiFi Range Extender(EX3700).I do not know the firmware but for a few days the signal with the router is poor. (the connection is bad both in wps and through assisted installation).
How can i solve?- plemansAug 17, 2021Guru - Experienced User
What router are you connected to?
what size is your home?
what material are the interior walls of your home?
Is there a lot of people living around you? Maybe there's interference.
Have you tried changing wifi channels?
- Orchard547Aug 18, 2021Aspirant
Thanks for sharing this information this is useful.
