Genny28
Aug 16, 2021Aspirant
Problemi con extender
Salve sto riscontrando problemi di segnale del extender con il router. Ci tengo a precisare che dall'acquisto del prodotto fino a due giorni fa tutto funzionava senza alcun intoppo. Come posso risol...
Genny28
Aug 17, 2021Aspirant
The model is a AC750 WiFi Range Extender(EX3700).I do not know the firmware but for a few days the signal with the router is poor. (the connection is bad both in wps and through assisted installation).
How can i solve?
How can i solve?
Aug 17, 2021Guru - Experienced User
What router are you connected to?
what size is your home?
what material are the interior walls of your home?
Is there a lot of people living around you? Maybe there's interference.
Have you tried changing wifi channels?
