bikerant
Apr 28, 2020Aspirant
Problems connecting to NETGEAR Wi-Fi Range Extender EX2700
Hi, I've been able to pair the extender with my PlusNet router no problem (using WPS button); however, I'm unable to connect to the extender...tried several phones and an iPad...could see the extend...
- Apr 28, 2020
Oh my days...I've done it..! ...Using the ethernet cable from the PC to the extender and connected the PC to the router via wi-fi... I wish I'd known that before as it was pretty straightforward via that route. Phew!
Thanks for your help!
Tony
bikerant
Hi, thanks for suggestion but can't get this to work...
Just to clarify...
- extender sees my router and creates a netwk with _ext at the end
- My iPhone (tried a 5 and a 6s) sees the netwk in settings/Wi-Fi
- I try to connect to to it using the same p/w as my router
- it rejects the password
- I go to the my wifi ext URL (this post won't let me type the full address) from a browser (as recommended) on my phone but my model is not listed
- So I can't run the installation wizard
- If i try to tap the suggested iOS URL on the above page, I just get a blank page
What am I doing wrong, please?
TiA
Tony
Apr 28, 2020Guru - Experienced User
worst case scenario?
factory reset the extender, hardwire into it via a laptop/pc for setup.
It tends to go smoother.
- bikerantApr 28, 2020Aspirant
Tony
