bikerant
Apr 28, 2020Aspirant
Problems connecting to NETGEAR Wi-Fi Range Extender EX2700
Hi, I've been able to pair the extender with my PlusNet router no problem (using WPS button); however, I'm unable to connect to the extender...tried several phones and an iPad...could see the extend...
- Apr 28, 2020
Oh my days...I've done it..! ...Using the ethernet cable from the PC to the extender and connected the PC to the router via wi-fi... I wish I'd known that before as it was pretty straightforward via that route. Phew!
Thanks for your help!
Tony
Apr 28, 2020Guru - Experienced User
worst case scenario?
factory reset the extender, hardwire into it via a laptop/pc for setup.
It tends to go smoother.
bikerant
Tony
