FabEX21
Feb 02, 2021Tutor
Problems EX3700 linking to Sky router
Router isn't yet connecting to EX3700 wifi extender without the ethernet cable being plugged in. Anything I can try? Cable currently trailing up the stairs. Devices connect to the extender successful...
- Feb 02, 2021Glad to hear it! If you make it solved, it could help the next person with this issue
Feb 02, 2021Guru - Experienced User
What sky router is it?
how are you attempting setup?
Using the installation assistant or using WPS?
What firmware is on the extender?
FabEX21
Feb 02, 2021Tutor
the sky router is er115 Q router i think
followed booklet instructions...not wps
extender used out of the box only got it today
- plemansFeb 02, 2021Guru - Experienced User
have you tried setting it up using wps?
you can have the extender in the same room during setup (so you don't have to run the cable). then just move it where you want when its setup
- FabEX21Feb 02, 2021Tutor
pressed the wps button nothing happened.
the unit works as i can connect to it from devices and it is much quicker but only if the unit is connected to the router.
Did you rerun setup with the extender disconnected from the router?
You can't have it connected to the router with a cable during setup or it sets up in access point mode.
