Papajedi
Dec 28, 2020Follower
problems with Model EX6110, AC1200 extender
I bought a AC1200 wifi extender model EX6110 about 18 months ago to get wifi to my Ring door bell. it worked for when we had a Virgin Media rounter. Since moving to Sky I cant get it to work. Looki...
Dec 28, 2020Guru - Experienced User
what router do you have?
What firmware is on the extender?
did you set it up using wps or using the installation assistant?
I'd recommend factory resetting the extender and instalilng using the installation assistant for best results.
