Yeetmeister
Feb 11, 2020Aspirant
Problems with wifi extender EX2700 after power outage
I bought an EX2700 a few weeks ago as an ethernet alternative and its been working amazingly giving me 30-40mbps download and 10-15 upload. We had a sudden 8 hour power outage on sunday and now it si...
Feb 11, 2020Guru - Experienced User
Yeetmeister wrote:
Thank you for he reply; I use a BT router and the connection was smooth at 2.4... as for switching channels I do not know how to do that so if you could reply with a method that would be great. Thank you.
You switch the channels on the router.
You'll have to look up your specific router manual to find how to change its wifi channels. there's several BT routers.
Yeetmeister
Ok thank you: as for the speeds, before the outage I did around 30-40mbps down and 10-15up but now I do 5-15down 3-8up I also believe my router (and the routers in my area) are all on the same channels as before.
- plemansFeb 11, 2020Guru - Experienced User
What speeds do you get directly from the router over 2.4ghz? Not from the extender.
this is key. the extender can't perform faster than the router is because the routers wireless is what the extender is running off. If something happened to the router to cause a lowered speed or a changed channel to a more congested channel, then it impacts the extender as well.
Its like a garden hose. it doesn't matter what type of end you put on the hose if someone is standing on the hose, its still going to come out in a trickle. Make sure there aren't any issues with the router's performance first. Test the routers 2.4ghz speed where the extender is. If its the same speed that the extender is getting, its because of the router.
- YeetmeisterFeb 11, 2020AspirantI think I understand, from a wireless connection I got around the same (before cut) down/up (just a bit less) as I mainly got the extender for download speeds. But I did get from 20-35down wireless and around 8up
Yeetmeister wrote:
I think I understand, from a wireless connection I got around the same (before cut) down/up (just a bit less) as I mainly got the extender for download speeds. But I did get from 20-35down wireless and around 8upOn what? The router? The extender?
did you try logging into the router to test different channels? I'd recommend 1-6-11.
