Yeetmeister
Feb 11, 2020Aspirant
Problems with wifi extender EX2700 after power outage
I bought an EX2700 a few weeks ago as an ethernet alternative and its been working amazingly giving me 30-40mbps download and 10-15 upload. We had a sudden 8 hour power outage on sunday and now it si...
Feb 11, 2020Guru - Experienced User
Yeetmeister wrote:
I got those down/ups on the router without the extender and the extender just boosted them to 30-40down and around 10up
So you're back to full speeds???
Or what speeds are you getting now directly from the router?
Yeetmeister
I may have explained it badly but I’m talking about what it was before the outage; now with the extender It usually fluctuates from 0-15down but then will go to 40 and back down and it will go to around 5up but will go to 12 showing that it’s possibly capable of going back to peak but there is perhaps a hinderance
- plemansFeb 11, 2020Guru - Experienced User
Yeetmeister wrote:
I may have explained it badly but I’m talking about what it was before the outage; now with the extender It usually fluctuates from 0-15down but then will go to 40 and back down and it will go to around 5up but will go to 12 showing that it’s possibly capable of going back to peak but there is perhaps a hinderanceI get that the extender does that. What I'd like for you to test is your phone speeds going to the router in the location that the extender is in.
- YeetmeisterFeb 11, 2020AspirantWhen my phone is next to the extender it’s speed is maximum (as in full bars on WiFi)
- plemansFeb 12, 2020Guru - Experienced User
Yeetmeister wrote:
When my phone is next to the extender it’s speed is maximum (as in full bars on WiFi)Full bars on wifi isn't a speed or any type of accurate measurement.
Use the speedtest app/program for both devices. Also make sure you're on the 2.4ghz if you're speed testing. You can't compare 2.4ghz speed to 5ghz speed.
- YeetmeisterFeb 12, 2020Aspirant
30down 8up
