jasonleschnik
Oct 17, 2010Aspirant
Problems with WN2000RPT Range Extender
Hi all! Just bought a WN2000RPT range extender and i have it all setup. I'm having a strange problem where every couple of hours randomly my hosts on the other LAN segment seem to not be able to pi...
alexbleks
Jan 31, 2013Aspirant
PM_Anwarson wrote: Hi yall
Here's my solution to this problem:
1.go to www.mywifiext.com & log in
2.go to setup > Ip adress setup
3.set to Use static ip adress:
to set your ip adress, just change the number after the last dot (this number should be OUTSIDE the range of your modem/router's dhcp server). The ip adress of your modem or router shoudl already be in the gateway box and the primary DNS is already set, so don't touch that, okay boo?
4.apply.
5. As you go to maintenance > status, you should now see that your DHCP client is OFF.
6. Now log out.
7. log in on http://www.mywifiext.net/cgi-bin/hidden_dhcpd.html with the same password & name as the first site.
8. Click Enable internal DHCP server: if all is right, it has already set a range for you. This range should NOT be the same as your main modem/router's DHCP range.
9. Click Apply and close window.
10. Now break the connection with your extender...... wait a moment...... make connection with that thang and all should be good FOREVER!!
If this helped you out, your welcome.
If it didn't, well it helped me :)
Latahz
Will this help me to hide my connected computers to the WN2000 from the other network?
I've been looking for a solution to do that without have to use a extra router AFTER wn2000RPT.
