Fionncraik
Nov 10, 2023Aspirant
Product EX6110 won’t connect to WiFi router for more than 1 second
When I connect my router to my WiFi extender though wps it connects for a second then disconnects and it says no internet on my phone. I have reset the Netgear extender and nothing changed I have done...
Fionncraik
Nov 11, 2023Aspirant
It won’t connect to the internet but I will connect to the router I think that is the problem. The access point is made but the router doesn’t detect an internet connection even though there is one. Any advice?
Nov 12, 2023Guru - Experienced User
What router are you connecting it to?
What modem/gateway is the router connected to?
