Ommadawn
Sep 25, 2011Aspirant
Prosafe 802.11g WAP
I have been told that I can use a Netgear Prosafe 802.11g WAP as a signal booster. Basically the problem is that my client lives in an old three story house. Their wireless router is situated on the m...
HenrikSandqvist
Consider using a couple of HomePlugs to create a small LAN-segment between your brodband router/switch and the other floors. Then attach plain WLAN AP:s on each floor. No fuzz with repeating/bridging configurations etc. I've got a FVS336G as my main router/firewall/switch and then three WAG102 on three different locations using homeplugs to connect the APs to the LAN. Haven't looked at the specs but there are also wireless extenders (HomePlug+WLAN AP in one unit) that also might be suitable.
Cheers
/Henrik
Cheers
/Henrik
