strandeng's avatar
strandeng
prosafe wg103 - how do i connect to ifit device
i have purchased ifit wireless device from ifit.com
i am using netgear prosafe wg103 access point.
the ifit recognises device, but will not connect.
message reads :-
Four main reasons for a failed connection:
1. DHCP - make sure that your router has DHCP enabled.
2. 802.11 B - The iFit Live Module only broadcasts on 802.11 B signal, make sure that your router is broadcasting either mixed mode that includes B or just B.
3. SSID - The iFit Live Module can only connect to SSID's that are publicly broadcast, make sure that your router is broadcasting its SSID.
4. MAC Address Filtering - Some routers only allow certain MAC addresses to connect to them. This is common with routers that are configured by your ISP (Qwest, Comcast, Verizon).
how do i solve this problem?
:confused:
