Acedoug's avatar
Acedoug
Query powerline wifi in multiple rooms
Hi, I need to put in wifi in multple rooms the walls are to thick to cable inan old house I need to know what powerline equipment would be suitable please. Regards Acedoug
  • plemans's avatar
    Mar 23, 2020
    you could try powerline, you could try moca adapters, you could even try a mesh setup if you were so inclined. I can't tell you 100% what will work the best because i'm not there.
