Acedoug
Mar 20, 2020Aspirant
Query powerline wifi in multiple rooms
Hi, I need to put in wifi in multple rooms the walls are to thick to cable inan old house I need to know what powerline equipment would be suitable please. Regards Acedoug
- Mar 23, 2020
you could try powerline, you could try moca adapters, you could even try a mesh setup if you were so inclined. I can't tell you 100% what will work the best because i'm not there.
Acedoug
Mar 23, 2020Aspirant
Hi
Thanks for reply. I believe the place was rewired a couple of years ago. So having discussed with the owner they need something in as soon as possible. What would I need to do four rooms wirelessly? One room has a router (zyxel)
Regards
Acedoug
Regards
Acedoug
Mar 23, 2020Guru - Experienced User
